Wiring Two Dual Four Ohm
Yes.Wired parallel, the subs will be at 1ohm at the amp. Wire each voice coil + to + and - to -. Then run them to the amp. Rockford Fosgate and other sites have handy woofer wiring wizards, which will help you with the configuration.
Again, the formula is...
Series: add up the ohms for each voice coil.
Parallel: divide the impedence of each voice coil by the total number of coils.
So if you have two dual 4's, that's four coils. Wire 'em in parallel and that's 4/4 = 1ohm.
The kicker amp is not 1 ohm stable. If you wire to 1 ohm it will go into protect. You have to series the woofers then parallel them. You will only be able to run it at 4 ohms.so you will get a little over 500 watts
ken2516
ken2516
albany ga
prcwitt
NorthFramingham
    Jun 30, 2026
