silenkiller
Alright. Obviously I'm fing up the concept here. I did a search and I found this:
"Allright ill try to make it easy ..
1. Your going to have one AQ2200d set to ouput/master in which this amp will receive the RCA's from the HU
2. Have the other AQ2200d set to input/slave
3. You will need a single rca wire to connect the two amps together .(the rca jack is next to those switches)
4. Connect both power and grounds as you normally would, Same with the remote wire.
5. Now connect the - of both amps together.
6. The tricky part .. Connect the + of the MASTER amp to the positive lead on the subs. Then connect the + of the SLAVE amp to the negative leads of the subs.
Side note: For daily make sure its a minimum of 2ohm load. If you are doing burping and so on you can drop down to 1 ohm . Def would not recommend having it at 1 ohm for daily . Amps would not like it .""
Is that the correct way to wire these? Obviously theres 4 RCA inputs, and I only have two rca's from my headunit. Right now I just have the left channel in one, and the right channel in the other. lol xD
Also, doing it this way, I'm assuming I've wrecked the way I've wired the subs. I have them each wired to 1ohm because I thought that they would be on their own amp. The way its saying there, It'll be seeing .5 to both amps right? Ahhhhhhh..
