Wiring to trunk
Dont go through the wheel well. Just connect it to the battery , take it to the rear of the engine bay, and drop it straight down. Then bring it back along the frame rail.
The only hole you MIGHT need to drill is one up through the trunk to bring the wire in.
But do NOT drill a hole in the wheel well. That is a horrible idea having wire right by your tire.
what size wire? if its small enough.. you might be able to get away with running it on the side of the hood and through the door
but bets bet is to drill a hole in the firewall and make sure you use a rubber grommet
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif:wow://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif:eek:
What kind of car is it? I think I can help you locate either a place to run it threw or a good place to drill a hold for one. You could also run it within a grommet that already has something going threw it.
go to any auto part store and look at their pcv grommets. they come is all different sizes and cost less than $3. pick the one that best matches your wire size.
nchilds21
nchilds21
Falls Church, VA
nineball
vegang
vegang
