Wiring Though The Box
99durango5.9L
NY
in the bottem right corner of the box there are screws or something coming out....does he run the wire from inside the box to those then from those to the amp?.....because right now mine are coming out the port...i wasn't sure
Edit....i can't spell Through...not Though
Just drill a hole in the back of the box, run the wire through, and seal around the wire.
That's a quick, cheap way.
Or, the best way is to just buy a terminal cup.
I actually like doing the bolts through the box. I had to terminal cup at the time and was like ok just tap and shove them through. Worked good and saved money on buying a cup not that they are alot of money, but yeah I would do it again just for the turnout.
thats the best way to do it is drilling the hole and then sealing it after you put the wires throught iv burt up alot of terminal cups because they cant handle all the power running throught it i mean there plastic and if you have even 1000rms running throught it, it still burnt up on me
you burnt up a terminal cup?
everyone knows to only use 3kwrms terminal cups
Plastic is a good insulator. Something isn't right if your terminal cups are BURNING.
no
I dont think so
its not a conductor
so you either had sparks and heat flying off of the wire leads, or it never happened
and if you had enough heat on the cups,they would have caught the box/car on fire
99durango5.9L
99durango5.9L
NY
djman37
NorthFramingham
    Jun 30, 2026
