Wiring Though The Box
Its setup like that so he can change the ohm load without taking out the subs.
Each sub is DVC. Each coil has a + and a -. 2 +s and 2 -s on each sub, so thats 4. 4 wired coming from each sub x 4 subs = 16. Thats how many wires go to the terminals on the box.
That way he can go parallel to series or vice versa without taking the subs out, by just swaping a few wires.
Its a really simple idea...
it dint catch on fire jackass it melted the plastic, and if you think im lieing when my brother comes ill take a picture same thing happend with his 3 10" L7s in a ported box a couple of times it got to hot and the plastic melted so we had to run it throught were it melted at
Are you galamonkey with 4 18 BTL'S? if you are you are my hero...
okay
I want me some pics
i really like how steve's box looks with the screws coming out....so since my subs are DVC subs there should be 8 screws coming out of the box....right?....i'd connect all the positive on the top...the negative on the bottem....then i could wire them parallel or series from the screws on the outside of the box.....just wanted to make sure i understood that correct....
High Current binding post.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-314
all binding posts:
http://www.partsexpress.com/webpage.cfm?&Webpage_ID=3&CAT_ID=39&ObjectGroup_ID=107&SO=2
or
just use nuts and bolts.
just drill a exact hole size, shove the wire through and caulk.
99durango5.9L
99durango5.9L
NY
djman37
