wiring this sub together, which set up is right?
dalegribs
US
Trying to send 300 watts @2ohms from the sub channel of an infinity kappa five amp to a single kicker 10CVR124 (dvc, 4ohm)
the factory kicker manual states to connect the pos and neg to the first voice coil, and then wire it in parallel.
someone else recommended i should run the original positive to the first coil, negative to second coil.
or
as it stands right now, i have it wired as in the second image, and the subwoofer seems to be receiving barely any power.
Arent both those pics going to read the same? Or am i missing something. Am i being punked?
Haha! OP as stated by Mat3833 wire the negatives together on the sub then out to the negative on the amp and the run both positives together and and then out to the Positive on the amp. This will give you a final 2 ohm load at the amp. It's called wiring in series.
I guess my main question, the original pos and neg that come out of the amp, should i hook them up to the pos and neg of voice coil #1 . Or send pos to pos of voice coil #1 , and send neg to neg of voice coil #2 .
Don't you mean parallel?
and it seems like its not putting out much power because its not 300watts wont get ya much lol
lol. i originally had a subwoofer that was only getting 200 watts, and it bumped a lot more than this set up, so I am just slightly miffed.
after checking the amp and changing the levels around, i can officially say the amp has plenty of juice for a sub. the difference is night and day
ps- i am an idiot.
ps- i am an idiot.
Not an idiot. Just a noob. We're all noobs at some point... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dalegribs
dalegribs
US
mat3833
