Wiring the System
TheBaron929
RFJunky
345
VA
Alright, well i've gotten rid of some of my older stuff looking to pick up some newer stuff. I want to wire the whole thing correctly to get the best performance out of my equipment.
Here's what i'm going to be wiring.
Punch 250 x 2 Amplifier
Class AB amplifier, 30 A fuse, recommended (by crutchfield) 8 gauge power/ground
Punch 450.4 Amplifier
Class AB amplifier, 30 x 2 A fuses, recommended (by crutchfield) 8 gauge power/ground
The Wire Guide found on this board says that
Here's the problem.
If the 450 watt amp is taking 4 gauge wire, do i need a 2 gauge or 1/0 Gauge wire from battery? Or can i still feed a 4 gauge wire from batter & distribute it between the 8 & the 4 gauge amp power wires?
Should i not worry about the 4 gauge going to the 450 watt amp & instead just run 8 gauge to both amps?
Any help is much appreciated, including recommendations where i can find all the equipment necessary at reasonable prices & so forth.
Thanks
I'd just do a single 4g from the battery to the amps & use a distro block with very short runs of 8g to each amp. Those things don't need nearly enough juice to warrant 1/0. 2g would be nice if you plan to upgrade but not necessary - and tough to find anyway.
Just b/c an amp's terminals accept 4g/2g/0g doesn't mean you need that.
You didn't mention how long the wire run is - that's an important factor in the equation.
Oh, and for sources - Knukoncepts or partsexpress.com
it's roughtly a 15 ft run from battery to trunk, then more more than 5 feet from distro to either amp (probably more like 3 feet give or take)
also, i read on Knu Koncepts that if i'm only running a 100A fuse on the 1/0 Gauge wire my system can't possibly pull more watts than supported by the 100A fuse, so even if the 1/0 gauge wire is overkill - it's not like i'm going to overdraw on the battery right?
Alright so it's been decided i'm going with the 1/0 Gauge from Battery 15ft to distro block. 4 Gauge to 450x4 Amp, and 8 Gauge to 250x2 Amp. I'm actually planning to upgrade sometime soon, which would probably change the 250x2 amp to a 500x1 ish amp.
Anyway, question - if i'm running a 100 amp fuse off the battery. Do i need to upgrade my 90 Amp Alternator to a 120 amp? Or should it be able to handle it - considering i won't necessarily be pulling 100 amps constantly.
TheBaron929
RFJunky
TheBaron929
VA
TheBaron929
