Wiring subs
from what i can find online,because iv never done from expierence,that you can indeed run a dvc with only using on coil.downside is your power handeling will be nearly cut in half.but they say to short the coil you are not using by running the positive to the negitive of the same coil. but not sure how that would play out if that coil is fried.if i come across any other info i will let you know.
So this brings up another issue. I built the vented box per Polk specs (1.2ft3). Bravox wants a larger box, 1.4 ft^3. I can still make the box slightly larger, but not that large. Plugging the box size into Torres Calculator results in a box frequency of 30 Hz. Does this sound reasonable?
Vincer77
Vincer77
Near Nashville, TN
Vincer77
NorthFramingham
    Jun 30, 2026
