iceteebone 5,000+ posts
Banned
i have a rockford 1001bd amp and it is only stable down to 2ohm so would it hurt it if i tried running it at 1 ohm?
I'm assuming this is for daily driving...if so then yes it would not be good on your amp. If it were for SPL burps then it would not be a problem.i have a rockford 1001bd amp and it is only stable down to 2ohm so would it hurt it if i tried running it at 1 ohm?
nope...it is for daily driving. so there is no way to run a dual 2ohm sub at 2ohms?
Yes, that should be right, if that's what the strapped reading is....i have 2 of the 1001bd amps and if i use the bd sync cable to link the two amps together (their both rated at 1000 watts rms each at 2ohms) then i will be able to get 2000 watts rms at 2ohms and then i could deliver 1000 watts each to each sub then? i'm not sure if this is right so please let me know. thanks
Wow man, that's a tough choice...i was deciding between 2 element design e 12a's or 2 re hc subs
