Wiring RSD comps to get 2ohms?
4Nine
Just out of curiousity.
If I wired my mids to each other in parallel and my tweets to each other the
same way and then used one x-over for the mids and the other x-over
for the tweets I would get svc 4ohms speakers wired in parallel = 2ohms correct?
Or can this only be done with subs?
Will making that long of a run to wire them have a negative affect/effect?
4Nine
an ohm is an ohm, it does not matter if its 2 4ohm tweeter, mids or subs.. 2 4 ohm loads wired in parallel would equal 2 ohm, same as 2 4 ohm loads wired in series equals 8 ohm..
as far as wire goes, I don't know as im not a professional but I see nothing wrong with it.
Ok so ditch using 2 x-overs and seperating them and instead use 1 x-over.
If an ohm is an ohm and the x-over doesnt split power but actually seperates
freq. theoretically you could use 2mids and 2 tweets on one x-over right?
Now you have the abillity to use the amps 2ohm power.
When the freq. is sent to 2 speakers lets say the tweets, the x-over wont
know whether its sending it to 1 speaker or multiple speakers correct?
That answers that thanks for the replys.
It dont matter now I got plenty of juice for the fokkers....
I just got a x200.4......//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
4Nine
4Nine
Trinity,FL.
4Nine
vegang
vegang
