vandiar2
alright here is the deal. i am currently running two amps. I have a 4 gauge wire coming to the trunk to a block that has 2 8 gauge wires off of it. I am about to get a 1 ohm stable amp (probably sundown 1500) to wire two 12" 4 ohm dvc subs. my question is.. can I just run another power wire, say an 8 gauge wire from the battery to the trunk and run the 4 channel amp and use the existing 4 gauge wire to power the sundown? that is how I have it pictured... i could only assume I will have to do the big 3 as well. not sure if I need an extra battery or not ( 96 dodge neon, will be running 1500 rms +) if so, what are some battery wiring tips to get it to the main electrical system? still not clear on that. also if I have that 4 gauge wire running to the sub amp, good idea to add another in line fuse close to the amp? thanks guys, might have some other questions.. in the near future //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
