- Thread Starter
- #16
Thanks for all the help so far. I am still unclear on the first 2 questions:
1. Is it ok to use y-adapters to split the 4 channels of pre-outs from my deck to 8 channels going to the 2 4-channels amps? Is there a better way to do this?
2. Is it ok to run all 6 pairs of "cabin" components to the 2nd KX650.4 if I run 4 of the pairs in series to 2 channels? It won't drop the ohm load to dangerous levels but will there be enough power to run those speakers?
Hey guys,
I'm new to the forum but not to car audio systems. I just traded in my Mastercraft boat for a new one that has MANY more factory speaker locations. I am going to upgrade the whole system and I have some questions. I also posted a Visio diagram of the system to make it easier to understand.
3. Is it correct to wire the 2 Optima batteries in Parallel? Will that double the amperage of the batteries' output to the system?
4. Is 1/0 gauge large enough to wire the 2 Optima batteries together? It will only be an 18" run as the batteries are right next to each other.
4. Any other glaring issues with this system setup?
Thanks!
