limitedniner
Okay so i have two DVC 2 ohm type-r's and a hifonics bxi1206d mono amp:
I'm a complete noob with wiring and this is the first time ive actually been exposed to all of this so i need some help..i am looking to wire them in parallel at a 2 ohm load if this is possible.
So i will tell you what i think i should do and you can correct me when if i say something wrong..
1)I connect both banana plugs on each type-r (+,+) and (-,-)
2)I then connect the speaker wire to the positive input and the other speaker wire to the negative input on the sub
3)I connect those wires to the positive and negative leads in the terminal cup in the enclosure
4)I do the same for the second sub as well
5) I then connect the positive wire to the positive on the amp and the negative to the negative on the amp
6)I do the same for the second sub since the bxi1206d has 4 inputs even though its a mono block
I found this on another thread and this is what it will look like even though his subs are 4 ohm:
All help is appreciated
Thanks!
Thanks!
