mokedaddy
professional idiot
Autozone should have them in stock. You take the relay and wire pin 85 to the remote wire of your head unit. Pin 86 goes to ground. Either 30 or 87 go to the battery. (it doesnt really matter but I usually wire 87 to the battery) and then I wire 30 to the power of the inverter. (or 87 if you used 30 for the battery).
Fuse the wire on the battery according to the size of the wire. 12 ga should be sufficient.
Also should note that I was generalizing that you have an older vehicle. If you have a newer or higher end car you should always wire anything aftermarket this way as to avoid problems with the on-board electronics.
