anyway to get GOOD bass response from a component set?
reed dollaz
i was playing around at walmart and was putting some of my cd's in the home "boom box" systems. one of them had four 4" midbass woofers, and seriously sounded like a decent 10". is it because of the way the tower is designed? and are car component systems not made for bass response like this? itll be a while until i get an amp for my subs and i have barely any bass, if any. some songs, a little. most songs, none at all. any way i can get better bass response? im running a 6.5" midrange comp set. i say midrange because it has the cone coming out of the center of the woofer. the midbass ones look like mini subwoofers, right? is that the type of comp set i would need for better bass response? sorry for the noob question. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Sealing up your doors should be your first step. The holes that your door panel has hinder you from having a true IB setup for your front speakers. If you can seal those hole, as well as add a few layers of sound deadening, the low end response from your front stage will increase drastically.
There are a ton of variables that affect how a speaker responds to it's environment. Unfortunately, a car door exhibits some of the worst conditions for a speaker, next to just submerging it in water.
Creating a stable platform for the speaker, and limiting resonance around the speaker is key. Reflections within a cabinet are bad as well. Making sure the speaker is decoupled from the mounting surface can benefit as well. You also need a fixed volume of air by either creating a sealed or vented enclosure, again very difficult to do in a car door.
I'm not going to go into how to create the best possible environment out of a car door as there are many, many methods, and many products designed to accomplish this.
Start searching.
Step 1: Deaden the crap out of your doors
Step 2: Make an MDF ring for your speaker
Step 3: (I don't see this often, but it helped me) Seal the area between the speaker and grille with weatherstripping
well i have an MDF baffle on the outside of my door as seen here:
i have since replaced those kickers with the eclipse's in my sig. ive also noticed, with my windows up the midbass is exactly how i want it. with the windows down, all u hear is highs. must be all the noise from the outside thats killing the bass response (being able to hear it) i will deaden my doors, when im not so impatient. my doors are LOADED with all kinds of bars, switches, metal plates.. all kinds of crap.
reed dollaz
reed dollaz
Ocala, FL
krisfnbz
