ok lets see if i can explain this rite...i have 4 RE8's. they are DVC 4ohm. Can i run one amp to the 1st set of al 4 vc's. and then the exact same amp to the other set of all 4 vc's?
you still better match the gain on the amps or you could power 2 of the subs harder and blow the 2 weaker ones. if that makes sence to you.ryan..... just hook up two subs to each of the amps, if the amps are the same, then it wont matter if you run two subs to each sub or if you hook up one coil on each sub to one amp, but if you did it that way you would be spending more time trying to make the setting exactly the same....
