wiring leds and fans
missionpilot
i plan on using a relay to power my four fans, and some leds that i have laying around. my dad said something about series or parallel wiring them. I know how to series and parallel wire subs, but i don't know anything about electrical. So please tell me the advantages and disadvantages, and what i should use in this situation. Thanks John
PS - would i series or parallel them the same way i would a sub?
Wire them all in parallel. All the +'s go together and all the -'s go together. Make sure the relay can handle to total current draw of the LEDs. Use a separate relay for the fans and the LEDs.
The reason you want to parallel everything is voltage. In a parallel circuit every load in the circuit gets the same voltage (12V in this case) rather than sharing the voltage as they would in a series circuit. Running the full 12V to every component will ensure that the fans spin at full speed and the LEDs are as bright as they are supposed to be.
missionpilot
missionpilot
Gulfport, MS
missionpilot
