Wiring harness help for FORD taurus compatibiliity help. plzzz
no. that won't work because you have a digital climate control system.
you need this:
Metra Electronics
Stock No. 99-5719
TAURUS/SABL 04-07 ELECAIRBAGT
so you have a LOC feeding an amp? the factory radio and LOC provide a signal to the amp. the amp provides the power. if you need more power, you need a larger amp, or to properly set the gains. i'm not sure a head unit swap will solve the problem you have, though it will help in other ways.
you need this:
Metra Electronics
Stock No. 99-5719
that indeed is the kit you need. and adding an aftermarket radio will make a huge difference. those ford radio's distort and actually reach a bass "max" at about 1/3 of total volume. completely terrible.
Chris.Bloemker
Chris.Bloemker
Orlando, Fl
x1le
