Wiring for subwoofer and amp?
BrandonBTR
Hello everyone I just joined
I have little to no knowledge in car audio
My question is what kind of wiring do I need for the subwoofer I have and amp
The subwoofer is a Clarion 10" Subwoofer 4 Ohms 900W Peak Power 300W Continuous power (just one sub)
The amp I am looking at is a Alpine 500W Class D Mono MOSFET with Adjustable Crossover, 300rms at 4Ohms
I have no idea what kind of wiring I would need to best support everything.
Also do I need wiring from the battery to the amp and then to the subwoofer?
Any ideas and suggestions would be greatly appreciated. Thanks
You can get a wiring kit from Walmart that'll support it. Once you get to high powers, you should upgrade, but 300 watts won't be a big deal. You have to run a power wire from the battery to the amp, a remote wire from the head unit to the amp, RCAs from the head unit to the amp, and a ground from the amp to a good, paintless part of the body of the car. Then, speaker wire to the subs and you're good to go! The kit will come with everything you need!
you just need an amp kit .most stuff you'll get at the big box stores will be junk.so either get one from one of the vendors here or search around the web for one
If you haven't purchased it yet, I would recommend knukonceptz.com
I asked the same question as you a few weeks ago, and a few of the guys recommended knukonceptz amp kits, so I went with that. Quality stuff!
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
935
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
Follow the wiring diagram provided https://euphoriacaraudio.com/product/ewx6neo/#wiring
BrandonBTR
BrandonBTR
Tennessee
dalegribs
    May 18, 2024
    May 18, 2024
