Wiring for a trailer help!!!
PartyInThRanger
Ambulance with Bass
Ok, so its not directly related to car audio but indirectly it is!
Here is what I want... I want lights on the trailer that i can use as turn signlas but when i hit the brake wont light up, any Ideas? also this needs to be using a standard 4 pin flat plug setup... Im thinking that it should be possible using relays since you can use the fact the when i hit the brakes both right and left turnsignals will want to turn on....
You could have a 4 pin and a 5 pin plug on the trailer and use the one that works with the tow vehicle.
You would lose the amber turn signals with the 4 pin but would be able to use them with your vehicle.
If the trailer will see any water at all (boat or jetski) than keep it as simple as possible.
PartyInThRanger
Ambulance with Bass
PartyInThRanger
Middletown, NY
Boris
