wiring DVC subs
depends on what the final load the amp will see and if it's optimal for your subs. what's the configuration of the subs and what's the amp?
if it's too low, then the amp will probly fuxor up or go into protect. you want the lowest safest load the amp will be able to handle that will be optimal for your subs vc config.
We will need to know what the coil impedance is on the sub.
Usually if they are dual coil they are going to be dual 2 or dual 4 ohm coils.
If you dont already have the subs and you have the amp you will need dual 2 coils so that you can wire the amp to 4 ohms a side.
You will want to bridge each side of the amp and run one sub to two of the bridged channels.
There is a sticky at the top of this section to help you wire them.
spacegear
spacegear
Ozamiz City, Ph
Johnny Drama
