Wiring dual power input amp
Strange, no mention at all in the manual.
Being a 1000w rms amp I would probably run an 8 awg pwr/gnd to each set of terminals. That should be adequate considering each wire is good for 50-60A.
If you want to run 4 to each that certainly wouldn't hurt anything.
I just ordered a reference 1.1000 amp, it has dual power and ground input,
How do I wire this thing up?
I'm running 4 guage to my amp right now
Can I out a distributor block From my 4 gauge and split that into 2 things of 4 guage? Or what
The idea is to run two unique power and two unique ground cables to the amplifier. I've never seen one with two remote connections but I imagine either will work unless they took two 500W amps and internally strapped them. But even then, I would imagine they would be wired together internally.
As far as power is concerned, if it's asking for two runs of 4 gauge power and two of ground, that's what I would give it. Worst thing that can happen is your amp will never starve for voltage. At least, not for lack of adequate power wiring.
RickyRoss91
PA
bbeljefe
Giles
    Jun 27, 2026
Giles
    Jun 27, 2026
