Wiring diagrams
12volts blue/yellow + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Power Lock purple - pin 33 at ETACS ECU
Power Unlock lt. green/red - pin 34 at ETACS ECU
Lock Motor blue/red 5wi pin 19, 28P plug below fuses
Unlock Motor blue/black 5wi pin 22 at ETACS ECU
Disarm Defeat blue/orange 5wi pin 17, 28P plug below fuses
Parking Lights+ green/orange + pin 5, 43 pin plug in DKP
Parking Lights- N/A
Hazards green/yellow - pin 55 at ETACS ECU
Turn Signal(L) green/blue + pin 22, 28P plug below fuses
Turn Signal® green/yellow + pin 27, 28P plug below fuses
Door Trigger -
Dome Supervision green/orange - pin 1,3 pin plug above fuses
Trunk/Hatch Pin white - pin 37 at ETACS ECU
Hood Pin blue/black - pin 24 at ETACS ECU
Trunk/Hatch Release green/white 5wi pin 32 at ETACS ECU
Power Sliding Door N/A
Factory Alarm Arm lt. green/black - pin 42 at ETACS ECU
Factory Alarm Disarm red - pin 25 at ETACS ECU
Disarm No Unlock
Tachometer white ac engine speed detect conn
Horn Trigger lt. green - pin 44 at ETACS ECU
:ladysman:1997 acura integra GS 4 door auto
12volts
white
ignition harness
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition
Third Ignition
Accessory yellow + ignition harness
Second Accessory
Keysense
Power Lock black/white - drivers kick panel
Power Unlock black/red - drivers kick panel
Lock Motor
Unlock Motor
Parking Lights+ red/black grn plug above fusebox
Parking Lights- green/yellow factory alarm (if equipped)
Hazards
Turn Signal(L)
Turn Signal®
Reverse Light
Door Trigger lt. green/red - drivers kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin green -
Hood Pin yellow/red - drivers kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock
Tachometer blue AC distributor
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray or blu/grn - steering column
Thanks mang, btw where'd you get all this info?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Directechs
Only if CC would get us a password...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Randy Savage
Randy Savage
New York
Randy Savage
