post my incar response graph for a 12" HC in 3.6@29 off 1200 watts in a 92 DeVille
Fs = 28 Hz
Qms = 6.33
Vas = 41.1 liters
Cms = 0.126 mm/N
Mms = 256.4 g
Rms = 7.127 kg/s
Xmax = 21 mm
Xmech = 31.5 mm
P-Dia = 247 mm
Sd = 480 sq.cm
P-Vd = 1.006 liters
Qes = 0.39
Re = 1.1 ohms
Z = 2 ohms
BL = 11.3 Tm
Pe = 1200 watts
Qts = 0.36
no = 0.223 %
1-W SPL = 85.5 dB
Fs = 28 Hz
Qms = 6.33
Vas = 41.1 liters
Cms = 0.126 mm/N
Mms = 256.4 g
Rms = 7.127 kg/s
Xmax = 21 mm
Xmech = 31.5 mm
P-Dia = 247 mm
Sd = 480 sq.cm
P-Vd = 1.006 liters
Qes = 0.39
Re = 1.1 ohms
Z = 2 ohms
BL = 11.3 Tm
Pe = 1200 watts
Qts = 0.36
no = 0.223 %
1-W SPL = 85.5 dB
