Wiring CS 465.25 2-Ohm Germaniums using 4-Ohm / 4 Channel Amp?
WiCKeD 5.9L
Set comes with 2 crossovers, 2 tweeters and 4 woofers running at 2 Ohms.
How do I wire the PG Xenon X200.4 amp at 2 Ohm stereo for the Rainbows?
There are 2 crossovers. Each routes power to 2 woofers and 1 tweeter. Could I run a cable between the left front positive and left rear positive to bridge them and run that into the tweeter positive? Then I would do the same thing with another cable into the woofer positive?
...or run left front positive into the tweeter/woofer positive, right front negative into tweeter/woofer negative, repeat for the rear channels and second crosswoofer and then jumble my RCAs around?
Here is a page from the manual:
Xenon Outputs:
WiCKeD 5.9L
WiCKeD 5.9L
San Clemente, CA
WiCKeD 5.9L
