Megalomaniac
Mr.SQ
This is part 2 to my original thread from wiring an auloc http://caraudio.com/forum/showthread.php?t=180843&highlight=auloc
Can someone help me if this is correct on wirng a relay to help maintain the voltage from the acc wire.
I found my old notes from when i wired my lcd screen to my ignition
86 is ground
30 is to the monitor cable positive
85 is ignition
87 is constant 12v
87a do not use
so with that same notes i came up with this
86 is ground
30 remote wire
85 is acc wire
87 is constant 12v
87a do not use
here is the schematic that is on the relay,i had to generate one up in paint.
86 is ground
85 is ignition
87 is constant 12v
87a do not use
86 is ground
30 remote wire
85 is acc wire
87 is constant 12v
87a do not use
