wiring and fuses reccomendations
swangandbang
2 x 15" Mags, SAZ-1500d
CDT EF-61 2-way component set
Rockford Fosgate P4002
200A Alternator
Pioneer Premier DEH-P880PRS
Red top in front, red top in trunk
I'm going to be doing big 3 + installation of all of the above.
Where do I need fuses for my particular setup and at what amperage?
Also, where do you suggest I should get my wiring from?
fuse from the battery (within 18 inches) to the alternator, fuse from battery in trunk to amps. fuse it according to the wire. for the bat to alt if youre using 0 gauge, use a 300a fuse. for your amps, if you use 0 for the sundown, use 300a, if 4 gauge is think it was 120a? could be 140. do the same for the rockford. for wire, i like knukonceptz wire, its big and cheap. http://www.weldingsupply.com is also fairly cheap.
swangandbang
swangandbang
Austin,TX
jacka
