Wiring an LOC
Alright, I got a diagram! Now I just need to figure out which wires for the LOC. I'm thinking the bolded wires (see below) should do the job.
Audio Amp C1
1-TN-Left Front Low Level Audio Signal (+)
2-D.GN-Left Front Low Level Audio Signal (-)
3-D.GN/WH-Left Rear Low Level Audio Signal (-)
4-BN-Left Rear Low Level Audio Signal (+)
5-OG-Radio Mute Signal
6-PK-Radio On Signal
7-Not Used
8-GY/BK-Remote Amp Sense Line Signal
9-OG/BK-Right Front Low Level Audio Signal (-) / D.BU in early models
10-L.GN-Right Front Low Level Audio Signal (+)
11-D.BU-Right Rear Low Level Audio Signal (+) / OG/BK in early models
12-BK-Right Rear Low Level Audio Signal (-)
13 to 16-Not Used
Audio Amp C2
1-BK-Left Front Tweeter Speaker Output (+)
2-YE-Left Front Tweeter Speaker Output (-)
3-L.GN-Right Front Tweeter Speaker Output (+)
4-PU-Right Front Tweeter Speaker Output (-)
5-YE-Left Rear Speaker Output (-)
6-BN-Left Rear Speaker Output (+)
7-L.BU-Right Rear Speaker Output (-)
8-D.BU-Left Rear Speaker Output (+)
9-Not Used
10-Not Used
11-Not Used
12-Not Used
13-L.GN-Right Front Speaker Output (+)
14-D.GN-Right Front Speaker Output (-)
15-TN-Left Front Speaker Output (+)
16-GY-Left Front Speaker Output (-)
Audio Amp C3
1-OG-Battery Positive Voltage
2-BK/WH-Ground
3-D.BU/WH-Left Subwoofer Speaker Output (+)
4-L.GN/BK-Left Subwoofer Speaker Output (-)
5-Not Used
6-Not Used
7-L.BU/BK-Right Subwoofer Speaker Output (-)
8-L.BU/BK-Right Subwoofer Speaker Output (+)
On the radio should be a 24-pin connector (2-rows (A and B) of 12)
B1-OG-Battery Positive Voltage [i believe this is constant and not switched]
B3-PK-Radio On Signal (not 12v)
B6-OG-Radio Mute Signal (not 12v)
96TL
96TL
Brooklyn, NY USA
tez4life
Mike Mccabe
