Wiring a battery in the trunk?
Yes, I would run 1/0 from pos. of the front batt, to pos. of rear batt... making sure to get a good chassis ground (in 1/0) on both ends. Also, make sure you fuse both ends of the power wire between the two batts. Also, I would recommend a yellow top over the red top for car audio //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
so u dont need to run the negative from the front batt to the rear batts?
Personally, if I were going to have a G31 under the hood, and one in the back, I would find a solid ground in the back and use both 1/0 for power... of course, then you would need 4 fuses...
SofireGuy
WTF Mate?
SofireGuy
NC
scottiej
