Wiring 9 Dual 4 Subs
No What I Am Trying To Do Is Debate If I Strap Two Amps And Wire All 9 Up To Them Or Would It Be Better To Use Three Sep Amps One For Every 3 Subs
What I Have Are The Powerbass Xa 4000d If I Strapped Them And Could Get The Final Impedance After Wiring All 9 Together To Work I Can Save On Electrical Stress
I Have Enough Amps To Put One On Every Three But Everybody That I Talk To Says That The 4000d Want Take A Half An Ohm Load So I Would Have To Wire Them To 2.67
I Have Enough Amps To Put One On Every Three But Everybody That I Talk To Says That The 4000d Want Take A Half An Ohm Load So I Would Have To Wire Them To 2.67[/QUOTE]
I don't understand this. If you go one amp what is the final load you want to try and get?
Awesome Man That Is What I Needed To Know. I Am Wanting To Strap The Two 4000's And Run All 9 Subs Off Of Them. The Output Doubles From 4000 To At Least 8k, Depending On Voltage. I Know The Easier Route Would Be To Use Three Amps On All 9 Subs But I Will Lose Wattage Because Of The Final Ohm Load. Now I Need To Find Out If These Amps Can Run .88 Daily
Or you could get the exact ohm load you need to the pair of amps.
All nine can be wired to a 2ohm load, and present the strapped pair a 2ohm load (which would be 1ohm each).
Ideal situation //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
nG
Thanks For The Help Just Have To Find Out If Those Amps Can Run .88 Strapped.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Powerbass Says The Lowest Recommended:d Ohm Load For The 4000's Strapped Is A 2 Ohm Load!
cwill5
cwill5
dallas tx
Gebrochen
BP1Fanatic
BP1Fanatic
