Wiring 4 subs
luckyj86047
I now have 4-alpine type r 12inch subs they are the dual 4ohm subs i know if i wire all together like they manual says it will be a 2 ohm load so what is the best amp to use with this speaker setup without overpowering the subs i would like to use just one amp and get get 1000 watts of power going to each sub any suggestions?
a sundown 3500 would be solid amp fo what you looking for
---------- Post added at 03:29 AM ---------- Previous post was at 03:28 AM ----------
cresendo 3500 also
yeah i have already upgraded to an extra alternator and deep cycle battery have capacitors everything is o gauge wiring and i just ordered the cresendo amp do you think four alpine 12's ran off the 3000 watt cresendo amp will be pretty loud
Wow you move fast....
5 days ago you were asking what subs you should buy
http://www.caraudio.com/forums/subwoofers/522474-infinity-reference-1260w-12-inch-1200-watt-high-performance-subwoofer.html#post7731308
then 4 days ago you said you have 3 Kickers in a Ported box
http://www.caraudio.com/forums/amplifiers/522554-amp-power-wire.html#post7732379
2 days ago you were trying to get help designing a box for 2 - Alpine 12's
http://www.caraudio.com/forums/subwoofers/522769-lpine-type-r-subwoofer.html
Now 1 day later you have 4 Alpine Subs
What happened to the 3 Pioneer Amps on a 2 gauge wire that you had
What happened to the custom Slot ported box you had for 3 subs?
I think you should just slow down and get 1 setup to work correctly.
Seems like you want something different each day.
There is no magical setup that you will plug in and be happy with.
Also you say you have 2 alts now but just 3 days ago you only had 1.
Can we get some pictures of your setup, I think it will help us to help you.
If you want to run 4 -12's why not remove your rear seat? In my Nissan Titan which is bigger than your Toyota, my 2- 12's took up 3/4 of the rear seat so 4 - 12's in your truck need all the space back there.
luckyj86047
luckyj86047
winslow,az
Team TH (Donny)
