wiring 4 front speakers
paulie74
Hi all! Could be a silly question, but, Is it ok to wire in an extra pair of front speakers, putting the speaker cable into the head unit that is already powering my 2 dash speakers? So i have 4 speakers at the front and 2 at the back. Will I loose the good sound or wattage?
actually, the question is dependent on what speakers you are talking about. if you want a woofer in teh door and a mid/tweeter in the dash, then yes, you can do this if you provide a passive crossover. at a minimum, you'll have a high pass crossover on the dash mid/tweet. a low pass crossover is desired for the door woofer to prevent phase interference. in general, you don't want speakers to have overlapping response. choosing crossover points and slopes is important, as well as taking the resulting phase shift into consideration. a 12dB/oct and 18dB/oct crossover will have a 180deg phase shift around the crossover frequency. it's usually best to use the same slope for the low and high pass crossover points. if not, you may need to adjust polarity to keep things in phase.
so before anyone can answer your question, we need to know what speakers you are installing. make/model.
most amplifiers are 2 ohm stable in stereo mode - meaning they are rated to be able to power a 2 ohm load. when you wire a pair of 4 ohm speakers in parallel, the combined load is 2 ohms. you always want to know what impedance load you are presenting to an amplifier (hu or external). buying an external amp would allow you to power 4 front speakers and 2 rear speakers with increased volume and clarity (compared to a head unit).
paulie74
paulie74
brighton
>>SQL<<
