the speakers in parallel would each get less power then the woofer in series. 100% of the current will pass through that speaker, while 50% of that current will flow to each of the two other speakers.
the impedance of the OP's diagram would be 6ohm.
optimal solutions would be 4/3 (all parallel) or 12ohm (all series). non optimal (one speaker gets 4x power) would be 6ohm (speaker in series with pair in parallel) or 8/3 ohm (speaker in parallel with pair in series). 8ohm or 2 ohm are possible if one speaker is shorted, 4ohm is possible if two speakers are shorted. the only worse case would be all speakers shorted or speakers disconnected. these should be all of the combinations you can wire.
the equation for speakers in series is Req = R1 + R2, so that gives: 1.6 = 4 + R2. the parallel combo would need to be -2.4 ohm.
(also, ohm load is such a terrible phrase. almost like saying a car is "miles per hour fast".)
