Why would I not see a 1.6 ohm load that way, and why not wire them that way? In order to see a 2.6 ohm load I would wire 2 in series, and then parallel them with the last one. I don't see how either way is any better or worse.Edit: just saw they are all 4 ohm subwoofers. You will not see a 1.6 ohm load with that. You could wire them all to a 2.6 ohms load. But i would highly suggest not running them the way you have em
Thanks for the nothing calculator. Reread what I have posted, and then see if you have soething to add.
I thought that would only be the case if the three speakers were missmatched. If all three are 4 ohm coils I'm not sure how that is possible.Your subs will see different power wired that way. You need to wire all 3 in parallel.
Well then quit asking, and just hook the **** things up. Then YOU can let us know what happens. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifThanks for the nothing calculator. Reread what I have posted, and then see if you have soething to add.
Your being told what will happen. I other words, "YOUR QUESTION IS BEING ANSWERED" and yet you still refuse to listen. **** newb.I thought that would only be the case if the three speakers were missmatched. If all three are 4 ohm coils I'm not sure how that is possible.
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Because they're not all wired the same. There's a reason you won't find a single wiring calculator that shows that configuration. Because it doesn't work.I thought that would only be the case if the three speakers were missmatched. If all three are 4 ohm coils I'm not sure how that is possible.
Actually I did find info on it, but it involves 4 speakers vs 3.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Because they're not all wired the same. There's a reason you won't find a single wiring calculator that shows that configuration. Because it doesn't work.
You are an idiot that cannot read. Thanks for the contribution. I would have no problem accepting someones answer if they would give the reasoning behind it. So far all I have been told is "it won't work". I'm sorry, but I have been around message boards far too long to accept answers like that. Many people will post on what they have heard, or their opinion rather than fact.Your being told what will happen. I other words, "YOUR QUESTION IS BEING ANSWERED" and yet you still refuse to listen. **** newb.
