Wiring (2) 4ohm SVC, and (1) 2Ohm DVC.
AMPLIFIER-
I have a Hifonics Brutus amplifier 1600 watts@1ohm, 1200@2Ohm, 550@4ohm. Although it is a mono amp it has 2 sets of output terminals.
SUBWOOFERS TO BE ADDED
(2) 4 Ohm SVC. Rockford P2 10"
(1) 2 Ohm DVC Kicker L7 12''
My idea is to wire both Rockford P2's in a box for a final impedence of 2Ohm connected to one terminal...
As for the kicker I would like to leave it wired @ 4Ohm and connect it to the other terminal.
CAN THIS BE DONE??????? Without hurting the amp. Is this the correct method?
First, sit in your car with seat belt unattached and speakers in the passenger seat
Second, run wires in a neat fashion around neck.
Third, get your car up to about 15000000 miles per hour
fourth, throw the speakers out the window.
five. Repeat.
um....round 2 might not go so well;)
you cant mix a DVC 4ohm and a DVC 2ohm and it would be stupid to mix 2 brands of subs i asked the same question before and i read up on it a little bit its wrong to do it wont sound good its stupid to do
(1) Kicker DVC L7 2ohm 12" wired @ 4 Ohm
(2) RF SVC 4Ohm wired @2 ohm
Connected to the 2 terminals on my mono amp. What Happens?
What impedence is the amp seeing?
I am not concerned with equal distribution of power?
Hey KSKITKA, Do you like bass? Because I like bass. I want to add the 12" Kicker along side of the 2 RF 10''s. Why are you so against this idea?
because it is not effective to match different drivers and drivers of different cone areas.....if you don't want to listen, then don't ask us questions......
doublechester15
doublechester15
Chepachet
NightDrifter05
