Wires to amp
OK thanks what if it's not that?
Well if it's not then you have bigger problems. When you touched the wires together, were either of them connected or touching your amp?
Most likely, you blew the fuse, so before we digress and start exploring every little thing that could be wrong, go check the **** thing...
what kind of fuse is it? Theres basically 3 main types, AGU, ANL, and mini ANL. AGU looks like a cylinder, ANL is a large flat rectangle (about 1 inch x 2 inch in size), and mini ANL looks just like ANL but, well, smaller...
If your not sure just google the names and find a picture. After you know what type of fuse it is, look at your current fuse and see what the rating is (ex. 200A) then just look on ebay or on here for somebody selling the type of fuse you need. It's usually less than 5 bucks depending on what type of fuse you need.
Setty7
Setty7
Tallahassee florida
batmanwb
BP1Fanatic
BP1Fanatic
