wired correctly??
blimblam
im trying to achieve a 1 ohm load from 2 DVC 4 ohm subs.
that is what i did. if its not clear on sub B, it is pos neg pos neg.
I can't make out your diagram very well but to achieve a 1 Ohm nominal load from a pair of DVC 4 Ohm drivers then all four coil positives need to be connected (whether directly or indirectly) to the amp's positive output and then likewise for the negative coil inputs and the amp's negative output.
this is what i did:
SUB A's positive to 2nd positive
SUB A's negative to 2nd negative
SUB B's positive to 2nd positive
SUB B's negative to 2nd negative
one of SUB A's positive to one of SUB B's positive
one of SUB A's negative to one of SUB B's negative
one of SUB A's positive to positive on terminal cup
one of SUB A's negative to negative on terminal cup
or do i need sub B's pos and neg to the terminal cup then to the amp as well?
blimblam
blimblam
new orleans
blimblam
