Wire Terminals
rmzsuzuki89
What would be the best way to wire into the box. Best as in the most secure, and most current flow.
A friend of mine just drilled holes and fed the wire through, then just siliconed around to seal it up. I have also heard of people driving bolts through and wiring to them. If this will work, what type/metal bolt would be best.
My last setup used actual terminals that I got from Sound Advice. I siliconed the back of them in, but not sure if they were secure enough.
All advice is appreciated.
What would be the best way to wire into the box. Best as in the most secure, and most current flow.A friend of mine just drilled holes and fed the wire through, then just siliconed around to seal it up. I have also heard of people driving bolts through and wiring to them. If this will work, what type/metal bolt would be best.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-309
/thread
rmzsuzuki89
rmzsuzuki89
St. Pete, FL
rmzsuzuki89
