Wire size
Well at the moment I'm not running any really high quality equipment but I do plan on upgrading sometime would it be a good idea to get some good quality wire for the long run?
i cant remember who but a guy on this forum had 1900 rms and his 4 gauge wire was plenty he said. but outspoken is right go 0 gauge after around 1200 rms. My system is around 1200 and i use 0 gauge split into two 4 gauges.
the amp, but remember, if you ever plan to go bigger, do the big wire now... i had to go from 8 to 4 to now 1/0 and could have saved time and money in the long run, if you know your gonna stay at what you are getting then you'll be fine
also, look at rms not max for wattage on the AMP, that will tell you what you need to run...
Xero.Limit
Xero.Limit
Citrus, FL
outspoken
