OP S spr_f150 10+ year member Member 83 0 South Louisiana Sep 29, 2004 Thread Starter #16 Ok, I can get me hands on a 2 ga. wire that is used to make welding whips. I can get it for free. This should enough for the bx1500d, yes?
ANeonRider 10+ year member teamSSAudio.com 2,807 0 Saskatoon, SK, CAN Sep 29, 2004 #17 I did a run of 1/0 gauge to the trunk, then distributed it to 4 gauge for a 3 foot run to the amp.
ANeonRider 10+ year member teamSSAudio.com 2,807 0 Saskatoon, SK, CAN Sep 29, 2004 #18 And this is a good guideline to follow: http://www.the12volt.com/info/recwirsz.asp
OP S spr_f150 10+ year member Member 83 0 South Louisiana Sep 29, 2004 Thread Starter #19 This install will be in an ext cab pickup. Amp will go under the front seat, so not too far of a run. I would like to stay away from dist blocks, etc. since not too much room under the seats.
ANeonRider 10+ year member teamSSAudio.com 2,807 0 Saskatoon, SK, CAN Sep 29, 2004 #20 my dist block takes up maybe 2" by 3" space.
jtomsic 5,000+ posts CarAudio.com Veteran 5,261 47 Washington, Pennsylvania, United States Sep 29, 2004 #21 use the 4 gauge you'll be fine, make sure you get the ANL distro block though.
brandontw 10+ year member just some guy 2,997 3 Reno, NV Sep 29, 2004 #22 2 gauge welding cable will be perfect, thats what i used for my bx1500d
