wire size for bx1500
probably not.... i think the maximum you are supposed to use on 4 ga is like 1200watts or something, and if you are pushin 1500 then i would suggest using a bigger wire. I also heard that it helps with the electircal current too. If its gotta bigger wire it'll get a better current... i have no idea what the hell im talking about. it sounded good though right.
i used 2 gauge, but it fits right in the 4 gauge terminals. i got 50 feet from weldingsupply.com for like 44 bucks, and its really 2 gauge, unlike some of the cheap car audio brands out there, they call it 4 gauge and its really 6 gauge ect. ect.
4 gauge would work, but you really should use 2gauge and 5 feet would only be like 4 bucks from the place i said, and it comes in colors and you get free welding gloves //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Length of the wire has a large bearing on the gauge it needs to be. You may as well run more, hell I have 1/0 run just to run my SS Ref 604 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would go with 4 ga personally - with an ANL 100 or 125A fuse.
If you were going to be competing, blasting test tones all day long and really need that extra fraction of a dB then 2 ga or 1/0 might be of some benefit.
If you're listening to music - generally at moderate volumes, with an "exhibition" now and then, 4 ga will work just fine.
spr_f150
spr_f150
South Louisiana
brandontw
