Wire in 3.5mm straight - yes or no?
Gravaviel
I have an unknown model Sansui radio with input / output plugs resembling a Grundig radio.
Pin descriptors are:
1 - TXD
2 - RDX
3 - -+A (CD)
4 - -+U (CD)
5 - GND LINE OUT
6 - GND
7 - Line out RF
8 - Line out RR
9 - Line out LF
10 - Line out LR.
My question: is it possible to directly connect the wires of a 3.5mm jack to the (I'm guessing) #3 and 4 pins without a digital to analog converter, and if it's possible how exactly should I wire it?
I have found a forum post which makes me think it might be possible, however the sales person at a local car audio store said it isn't possible without a convertor (which makes more sense to me).
Nevertheless I'm very hopeful
Thanks and kind regards,
Gravaviel
I've posted a reply (since I couldn't create the post containing the links) referencing an image of the pin configuration, and a forum post I found where some guy claims he did something similar with a sort-of similar radio, however it is still awaiting a moderator's approval.
In retrospect, I could just give the links without hotlinking -
Plug / pin image: http://www.tehnomagazin.com/images/grundig3.gif (REFERRING TO PLUG C)
Forum post: http://www.fiatforum.com/bravo-brava-marea-guides/235822-how-make-aux-3-5-mm-jack-cable-grundig-ad-185-h-m-radio-casette-player.html
Gravaviel
Gravaviel
South Africa
Gravaviel
