Wire Guage?
  • 4
Here is a quick idea of which size wire to use at 16 feet.. If it is less add a bit more..etc.
10AWG - 200 watts
8 AWG- 500 watts
4 AWG-1000 watts
02 AWG-2000 Watts
01 AWG you can power a city block with this stuff dont worry about it.
Mike
Ok, so if I need a four guage does this sound like everying i need?
17 feet of 4-gauge translucent red power cable
3 feet of 4-gauge translucent black ground cable
AGU fuse holder and 50-amp fuse
17 feet of 18-gauge tinned silver turn-on lead
2 platinum-plated ring terminals
wire ties
protective grommet
This is from Rockford Fosgate, What are all the wires that i need to hook my system up, and why is there only 3 feet of ground wire. Thanks
-Chris
Originally posted by Chris101 Ok, so if I need a four guage does this sound like everying i need?
wire ties
protective grommet
-Chris
Because you should always keep your ground as short as possible. Sounds like you have everything you need except for RCA's.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
378
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
867
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
992
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
993
Chris101
Chris101
MD
JTz62
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
