Winners only.
No you just said if you don't use both "channels" in regards to the monoblock...you ain't using all the amp...
The only logical conclusion is you'd have to bridge it 🤣🤣🤣
OK, let’s play. Here’s the quote of my post.
What amp are you using? Car amps don't just have "double outputs" that are wired internally unless they are Pyramid crap type of equipment.
Multiple outputs means multiple channels. Leaving them unused means you have amplifier power not being used.
Read it carefully. “Multiple OUTPUTS means multiple CHANNELS.”
If the amp had multiple OUTPUTS, then it would be a multiple CHANNEL amp.
Leaving OUTPUTS unused means the power from this CHANNELS is not being utilized.
A 20 position terminal block on a mono amp is only going to give you ONE set of OUTPUTS, not 20.
Now, it’s your turn to explain how using two CONNECTIONS for two subs versus four CONNECTIONS for the same two subs changes the impedance LOAD seen on a mono amp.
Go.
You don't understand how taking 2 4 ohm subwoofers and connecting one to each terminal on a monoblock reduces the impedence to 2 ohm seen by the amplifier?
I was concerned about the truth of what happened...same as now...I just don't like the orange man bad so he did it stuff...there'll plenty of time for blame once the facts come out...
I'd say the facts have been out on this one. This is ongoing issue that dates back to before the election was stolen. Ironically Trump projects this image of unpredictability, but he's actually very predictable. We knew he wouldn't leave office peacefully before he even took office. They knew he was going to take classified docs and he didn't disappoint.
Na
Nah you haven't...but since the beginning rob most definitely has...
Opps, I meant to say I don't recall Rob saying "get'em" (ie hang trump, put him behind bars, etc). He's a bit more adamant than I am that these docs are no long "alleged." IMHO, there is no more reason to believe the FBI is out to get Trump than that were out to get Hillary. Ironically, Hillary sang the same tune that Comey wanted to torpedo her campaign. Maybe these are just people doing their jobs, like rounding up classified docs because Trump didn't hand them over voluntarily.
Is it not labeled A and B?
[/QUO
I’m asking how it is different connecting them both to one set of terminals versus connecting each one to each set of terminals.
It was said it was ok to use one set and then went on to explain what would happen if BOTH sets got used.
What’s the difference?
It's a figure of speech...he's a bit beyond "more adamant" imo...
I don't know the full details about all this...there's credible reports trump has been working the fbi to resolve this since june...then there's the raid that happened...I do believe it's possible trump wasn't wholly cooperative...rep jordan also claims to have 14 doj/fbi whistleblowers...I also believe we're close to election season again so who knows...I'm not willing to make up my mind til I see more the scant info that has been released...
You don't have to wire the subs together if you use both...that's the whole difference...
But Trump wasn't working to resolve this - all he had to do was hand over the documents in question. This started prior to his even losing the election. There has been an issue with Trump keeping classified docs rather than returning them for years.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
