Winners only.
If he wired the subs together he could use one terminal to reach the desired impedence...or he could run a sub to each terminal and reach the same impedence...wtf is so difficult about that concept for you...
1) There was no such discussion or explanation offered.
which is just as well, because:
2) The 4 ohm SVC subs don’t have to be “wired together” to get 2 ohms at one set of terminals. Stick the fvcking wires in the terminals and tighten the set screws. 2 ohms.
Same 2 ohms if you wire a 4 ohm sub to each set of terminals.
Do you know about ohms law and serial/parallel wiring?
Do you think the subs get wired to a load?
No shi!t...You're the one that asked if it pyramid type crap and if you don't use all the terminals you ain't using all the amp ffs...
Read it again. I said in a multi-channel amp you are not using all power if you are not using all outputs.
Please explain how that is incorrect.
And please explain what you mean by needing to wire “subs together” before connecting them to a single set of terminals on an amp.
You said multiple outputs means multiple channels...while monoblock were being discussed...
The o/p did not list the amp he has, and he described multiple “outputs”. He said it was mono, but who knows if that is accurate if he is unable to even decipher the connection diagram?
Then CertifiedHoodClassic talks about each “output”.
Hispls mentions a distro block, and I ask what amp it is so we can give more informed answers. I am VERY clear that “multiple outputs” means multiple CHANNELS.
Then you decide to explain the difference in impedance if you use one set or use “a 2 ohm load into each OUTPUT”.
Tell us where I was incorrect.
And please show us all where I talked about bridging a mono amplifier.
And tell us why you think wiring two subs to one set of terminals on that amp is a different load on the amp than wiring one sub to each set of terminals.
I will ask again. Please stop speaking for me. I am grown and I can speak for myself son. It saves confusion for people reading these post.
It is my opinion that it is pointless trying to do anything right now under the ruse that it is for our future generations. This is literally what we are DOING for our future generations:
"Going green" but while it happens we will dump $trillions$ and $trillions$ in debt on their shoulders. But you want to point fingers at me because of my opinion.... really? Mine is just an opinion. Reality is what our government is literally doing right now to our future generations. But you seem to be fine with that.
And your boy Trump ran the deficit up $7.8 trillion and you are fine with that. You are a joke. So hypocritical.
Maybe Trump doctored up some allegedly classified documents. Perhaps FBI agents are too stupid to know what a classified document is? I suspect they knew exactly what they were looking for because Trump had a history of taking and not returning classified docs, so I assume somebody somewhere has a list of missing classified documents that were last seen in the Trump's possession.
Not only classified but top secret. And not only top secret but even a higher classification than that. It's not just simply classified documents.
My cousin just filled up for $.11/gallon. Save your grocery points up. This was in Olathe, KS yesterday. It happened.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
