Winners only.
See... already gearing up to argue aren't you? Let me explain it simply for you.... The test in America are irrelevant because hospitals get paid more money to label whatever sickness as COVID, Relating to COVID, Caused by COVID or whatever way they can attatch the letters C, O, V, I, D, so they can get a bigger government check.
The question was, "do all countries use the same test when testing for Covid?" I'm not worried about the conspiracy theory that Dr.'s are lieing about the cause of death.
Catch up kid. I asked do ALL countries use the same test? As in, is there one universal test that every country in the World uses when testing for the Covid virus? Jeez! What grade did you drop out in?
Dddd don't pp ppp p ppppick on mmmemmemmemmeee, Sometime my bbbb BBbbbrain doesn't www w www work rrrrright.
Oh jeez, my retarded stutter just kkkkk k kk k kkicked in. ;)
You can't keep up. First it was Regan and then you didn't understand a simple question about a World wide Covid test. It sounds like you missed school a lot, or, maybe altogether.
I understood the question just fine and I said the test in the US were irrelevant. The system is being misused by hospitals to get a bigger pay day from the government. So who cares if the test are the same or not. And silent A's after an E are as retarded as you.
The PCR tests have a a multiplication sensitivity factor, and they literally aren't designed to find stuff in humans, they're designed just to show presence of certain materials in like a lab test, like from a sample, like a testing dish or something. There's a sensitivity factor in PCR tests, and anything remotely close to COVID, like any other corona virus, was called COVID, because they cranked the sensitivity of the PCR tests up so high, that almost everyone who got tested, they tested positive, because the tests were registering everything. It's basically like a signal to noise ratio, the noise was so high in these tests that each test seemed positive, but it's wasn't covid they were showing was positive, just roughly covid like material, which is garbage. It's all designed to make a disease look way worse than it is.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
