Window sealing suggestions???
Did any of the base line vehicles come with fixed windows ? Check with dealer . My truck has pop out rear side windows but the baseline work truck had permanent fixed windows. I talked with a glass guy and he can order replacements and i will take out my pop outs and all the frame and hardware and the others will glue in like a windshield and no more SPL leaks and also more theft resistant than the pop outs ! Lol thats how i always break into mine when keys get locked in it !
I was unaware of that option! Thanks though, I need to look at all possibilities and I'll look into the base vehicles, they need to go though, can't keep them nope..
AquaSeal's pretty permanent. I've used it a lot in various whitewater kayaking applications. Even used it to seal up a hole in my waterbed mattress after we moved it and it got a small hole/leak in it. I found the leak, cleaned the vinyl waterbed mattress material and AquaSealed the leak shut. No more a leak in over a year, and i don't ever expect this leak to be a problem again, ever.
John Kuthe...
Have you ever used any with an spl application? It sound interesting and something I would definitely look into when I have a leak but how would it react to 4 level 5s with custom cones and smelly coils? They're putting in work back there, so it definitely has to be something that's not just leak proof but strong as can be
AquaSeal's pretty tough stuff, maybe not the toughest but I like it a lot. Tough enough for everything I've used it for. No I've never used it for a SPL application.
John Kuthe...
John Kuthe...
Ok, well thanks for taking your time to share that, I will do some research on it, I'm sure I can find a use for it to reasure no leaks.
DCbass
DCbass
Kinston, NC
DCbass
