Window Cranks
I bought a tool from Orielly's for I believe $6 bucks and it makes it a lot easier to take off the window crank. Also it has the other end of the tool that works for popping the clips holding the door panels on. Best $6 bucks I have ever spent.
Yea I have seen that technique used before also. Just slide it behind the crank and work it back and forth until it works the clip out. I was never able to get it to work on my truck so I bought the tool, other vehicles may be easier.
lol i had to do this on the same car, just get a flat head,,, there is a tiny ring behind the handle you gotta clip off..
i actually had alot of probs with this car.. first the speakers would hit the window... then i put in speaker rings and the window handles hit the speaker... i had them bent but eventually broke..
yea i forgot about the rag trick it does work on most, i just have had the tools for a while now so i kinda forgot that one.... just gotta figure out what side it pops off from.....
BigOleDom
BigOleDom
Ohio
yunvme666
