win ISD beta
Mat Dope
im using this program to make a box for my 3512 in 2cubes either 32hz or 40.
im going to use 4" flared aeros. i want to use 2 ports one on each side of the woofer. when i put in 1 port it says 13" length then when i put in 2 ports for the same tuning it says 29" length. is this 29" each port or 29" all togather?
Each port should be that length.
When you increase port area by using dual ports, the length of each port must be increased to compensate for the increased port area.
To figure the length of a port for a dual-port enclosure, each port should be the length of the desired tuning frequency for half the enclosure size.
For example; if you have two ports, each 4" in diameter, and a 2cuft enclosure with a desired tuning frequency of 32hz......then you "calculate" the length of each port based off of how long a single 4" port in a 1cuft enclosure would need to be.
If you model a 1 cuft enclosure with a single 4" port tuned to 32hz, and a 2cuft enclosure with dual 4" ports tuned to 32hz, the port length of all the ports will be exactly the same....30.11" according to my calcs, apparently 29" according to WinISD.
I did a really bad job of explaining that.... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Did it make any sense?
Do You ever? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
OMG !!! He's alive !!!
And no...I never make sense //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Glad to see you again mate //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Still fag free ? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
They say that quitter's never prosper... but I'm doing alright. :shrug:
Good to see that You're still spreading the disease, errr... knowledge. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I tried to walk away.....but real life is just too boring.....
walk away from this place? or the cheebah?
if it weren't for You minivan needs, I'd tell You to pick up a cheap project car to make fast. More fun more often.
But I "found" the Uberwoofer the other day, in the attic. ...caught the bug
Both.
Failed both times.
So is that where you've been hiding?
If You quit this place, it may well be easier to kick the other monkey too. Just spitballin here...
Yes. Matter of fact... I haven't even had a radio in my DailyDriver for a month or two now. //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
29" each.
There is no easy explanation...
Mat Dope
Mat Dope
east coast, florida
Mat Dope
michigan born
    May 14, 2026
michigan born
    May 14, 2026
