Will this works?
Hing
Iceflammer
Hi, need some advice
lanzar Heritage 12" sub
Power Handling: 500 Watts RMS / 1000 Watts Peak
Frequency Response: 30-1KHz
Impedance: 4 Ohms
Efficiency: 88dB
Single coil
Kicker KX400.1
Amplifier Type: Mono
RMS Power: 200W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: n/a
RMS Power: 400W x 1 @ 2 ohms
Bass Boost: 0 - 18 dB
Frequency Response: 20-200 Hz
Signal to Noise Ratio: >95 dB
Heard Kicker Amp are underated.
Wondering if this 400W amp is able to pump the above mentioned sub?
If not any recomendation
you can get a brand new hifonics brutus 1000D for $210. it does 500 rms @ 4ohms and 1000 @ 1 ohm in case you want to add an extra sub. //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
Hing
Iceflammer
Hing
Singapore
Hing
